Prop pitch ideas >
Prop pitch ideas
Prop pitch ideas
Old 08-05-2021 | 03:58 PM
😂😂😂 your right
Dagger11d is offline
Old 03-31-2022 | 09:08 AM
markt111's Avatar
Originally Posted by Dagger11d
4,700-4,800 sir
I assume your RPM range is 4600-5000 RPM, you don't note which 5.7 or the year. If that is correct you cannot turn more prop(higher pitch) you might be slighly under revving if it's 4700-4800 RPM when the boat is light.
Also I think your weight is off, I have a 285SSI the specs say 7200lbs dry with a single engine, you have twins, add a few hundred to that
markt111 is offline
