SCX prop help >
SCX prop help
SCX prop help
Old 09-09-2021 | 08:08 PM
General rule is 200 rpms per inch of pitch change.
If you start changing number of blades, rake or diameter, that affects rpm as well.
Griff is offline
Old 09-15-2021 | 05:25 PM
Would the 18 degree rake be causing my chine walk at top speed? 15 degree would give less stern lift correct?
sgett775 is offline
Old 09-23-2021 | 11:41 AM
Originally Posted by IGetWet
Hmm. 4.25” should be more boost than 7psi. I have 4.5” on my whippled 525s and I want to say I’m over 8psi. Smaller pulley equals more boost. The way I see it your options are
1. stick with same diameter props but lower pitch and get more rpms, but have same planing and max speed due to lower pitch.
2. Go bigger diameter, but I think 16 7/8” is max on scx, and lower pitch to gain some rpms and help ventilation. And your slip #s are already decent.
3. mess with spacers along with 16.5” diameter props to help with ventilation.
the rabbit hole goes deep. Your trimming to your sweet spot for the WOT runs? How much testing did previous owner do with setup?
IGetWet,
The question that was asked was about the pulley on the engine. A smaller pulley on the engine would result in less boost, not more.
Thanks. Brad.
Model Machine and Precision LLC
(937)545-8991
Brad Christy is offline
Old 09-23-2021 | 12:12 PM
IGetWet,
Thanks. Brad.
(937)545-8991
The OP said he had a 4.25 UPPER.
Originally Posted by sgett775
4.25 upper, I am looking for some 30 pitch props right now, 7000 dollar gamble.
cheech is offline
Old 09-23-2021 | 12:22 PM
IGetWet,
Thanks. Brad.
(937)545-8991
Huh? There was never any question about the pulley on the blower or the engine... Either way it’s irrelevant to the OPs question.
IGetWet is offline
Old 09-24-2021 | 06:22 AM
With 4 ppl and full fuel you’re not far off of 5600. You could see what’s out there for 31” or 30” pitch props. What size pulley do you have on the motors? 4.75”?
IGetWet,
I see where we went sideways....
You asked about the pulleys on the motors, the reply specified the pulleys on the blowers, and I missed that curveball.
I'll step aside now....
Thanks. Brad.
(937)545-8991
