Max RPM
That’s typical (ie: very insccurate) for dyno that uses airflow hat turbine and fuel flow meter to give a/f ratios. Instead of widebsnd O2.
OP: can you have them send you dyno chart with every 100rpm data vs the given 250 rpm steps ? Thanks
AFR's should be 12-13 range. If those are correct, its way lean on fuel.
Prop it for 5200-5300 rpms with a light load. It will drop 100-200rpms with heavier loads and higher temps/humidity.
Jeffer, as SB said if those aren't wide band readings they're just a calculated average so to speak.
I see the graph has an 05 date on it anyways, if it was dynoed back then and been running problem free since, my guess is you're good. Hard to say.
