Prop slipping?
#31
A higher pitch prop, 30, may help with your slip issue and speed, especially a 5 blade. My Daytona planes faster, has less slip, lower rpm at cruise and similar or faster top end with a Max5 or Maximus. If you want a lot faster on your Sunsation, look into installing a Whipple. It's only money.
#34
#35
Awesome. Glad that helped you. Save gas?? Then you're in the wrong sport! 😂 Did you try to open it up too? Tell you what, if that Max 30 doesn't work, I'll buy it for $750. Just LMK.
#37
Am I missing something? RPMs are going to come up when a boat comes up on plane! Once it is up on top there is less boat in the water, less resistance, less load and rpms rise. Also when figuring slip remember a Bravo 28 is closer to a 27.
Padraig
Padraig
