Hustler 266 prop height with notched transom. >
Old 11-24-2024 | 07:53 AM
Default Hustler 266 prop height with notched transom.
1995 hustler with a hp 500efi and bravo 1.50 drive bravo 1 26 4 blade prpo shaft is 41/2 inch below the keel . With the notched transom can i go to a shorty lower and gain peformance? Right now it carries the bow nice and can turn 5200 rpm. Any help would be great . Thanks
float n nutz is offline
Old 11-25-2024 | 12:02 AM
I doubt you could go to a -2 and still carry the bow. My 28 Pantera had a notched transom and at 3.5 below the bottom, it wouldn't carry the bow and responded very little to trim. I added another 1" of spacer and it was better riding and 2-4mph faster at all rpms
Griff is offline
Old 11-25-2024 | 04:20 PM
Default prop height
Thanks Griff i think i"ll leave it alone and maybe try a couple different props .
Old 12-04-2024 | 10:48 AM
What are you trying to get out of it? 26P 4 blade seems about spot on for your power.
madflavors26 is offline
Old 12-04-2024 | 04:58 PM
Just thinking maybe someone has found a better setup for the boat. With the clean water from the notch maybe a 3 blade less drag and easier on the drive. This has been a long project and with the help of FU marine tuning on the water she is just about ready.
