Tuff 16 Propeller advice >
Old 08-28-2025 | 07:46 AM
Default Tuff 16 Propeller advice
Hey guys.
I am looking for some help on choosing a new propeller for my Tuff 16.
The boat has a 60hp Mercury 4 stroke and came with a 13 spline 10” 17 pitch aluminum prop.
With this set up I can run 50mph at ~6000rpm.
The label on the drive shows 12x22.
I am wondering if I should try a 12x22 prop.
Should I try Aluminum, stainless steel, blade or cleaver?
Please share your ideas.
Thanks for the help!
blue89turbo is offline
Old 08-28-2025 | 08:07 AM
Going up 2 inches in diameter and 5 inches in pitch, you will struggle to turn that propeller if you are doing 6k on a 10x17. I would try going up to a 19 or 21 first before increasing diameter
CheckmateScarab is offline
Old 08-28-2025 | 12:51 PM
Thanks.
That sounds like a good idea. Maybe i will look for a used 10x19 or 10x21 and see how that works.
Old 08-28-2025 | 04:50 PM
If you want to know what works best - call Mark or Thomas @ Tuff.
They are great to speak with...
speicher lane is offline
Old 09-02-2025 | 07:27 AM
resurrected's Avatar
Where are you located? I have some props in that size range I use on my Thundercat.
resurrected is offline
