Explain this prop hub please
This is the hub of a Mirage Plus I looked at today. It's for sale locally. I'm no prop expert, but aside from the hub not being pushed in all the way, it just doesn't look right to me. Or is it ok? There are screws through the ventilation plugs to make them tight. They're visible in the one photo.
I've never seen a prop hub that went into a round bore and was retained by 4 pcs of roughly 3/16 diameter rubber. Is this something from between the old fashioned solid rubber hub/ with metal center mount and the newer mount that has a square in the prop and uses a plastic sacrificial piece with a splined insert?
Or is this for a fat shaft.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
