Formula 242 with high x-Dim.
What shape is your 502 in? New? Rebuilt? Tired?
Motor has been refreshed, new hone, new rings, valve job. had good compression. but maybe something is wrong with it? for me it feels like this 502 should spin a 23 mirage with no problems on this boat but what do i know
It should have no trouble spinning a 23p. My 242 with the stock 454 Mag would run 55 all day with a Mirage 23p. You should be seeing into the 60s.If you're trimming and gaining RPM but no speed, you're just slipping the and unloading the prop. 1.5-inch of change shouldn't make this big a difference.
Is the engine timed correctly? Setting base timing requires putting it into service mode and all that fun stuff.
We only spin 4000 Rpm, so this is not that high number of slip. I start believing the engine is low on power. I will check timing and all.
https://www.go-fast.com/Knowledge-ba...lip-calculator
