My 24 outlaw project >
Old 08-06-2013 | 06:45 AM
Thanks. I am using polyester resin on all the new wood. I just rolled the gelcoat on with a roller.
FBRONCO is offline
Old 08-06-2013 | 07:03 AM
Starting to rig it.
[ATTACH=CONFIG]505638[/ATTACH][ATTACH=CONFIG]505639[/ATTACH]
Attached Thumbnails My 24 outlaw project-100_1146_small.jpg   My 24 outlaw project-100_1147_small.jpg
FBRONCO is offline
Old 08-06-2013 | 03:56 PM
Great work! Looks great! I'm going to do a full re-rig at the end of this season, not looking forward to it but the boat needs it.
Sunrocket24 is offline
Old 08-07-2013 | 07:29 AM
Getting ready to drop the motor in.
[ATTACH=CONFIG]505706[/ATTACH]
FBRONCO is offline
Old 08-07-2013 | 10:07 AM
Fantastic! You will have a brand new boat. Did you have to get into the transom? I'm surprised that you had to do the cabin, I would not have thought much water would have gotten in up there. Was this a necessity or did you want to reconfigure it? Really nice looking work.
Dan
BajaDan is offline
Old 08-07-2013 | 12:11 PM
The cabin was fine except for some wet balsa in the deck from where the hatches were not sealed. I just wanted to replace the green carpet. The transom was in good shape. I just fixed up the bulkheads, some of the floor and the boxes in the back. Oh and I had some wet coring as well.
FBRONCO is offline
Old 08-21-2013 | 09:13 AM
Wow, that looks great!
Crossett is offline
Old 08-21-2013 | 03:46 PM
c_deezy's Avatar
Did you mount the k-plane pumps parallel with the transom angle or put a piece of angle behind them to shim them back to level? I have mine parallel and two of the three seem to leak because the oil level is higher in the rear of the tank than the front. Once they got below the seal they weren't as bad but still do when the boat bounces around.
If you can, I would shim the tops out so they are level, and not parallel with the transom.
Originally Posted by FBRONCO
Starting to rig it.
c_deezy is offline
Old 08-21-2013 | 05:29 PM
just built a hoist just like that
state1310 is offline
Old 08-23-2013 | 09:44 PM
I did not shim them. I did not have any issues with my last 24 outlaw when I mounted them that way, but maybe I just didn't get to use it enough. Shouldn't the o-ring seal it from leaking?
FBRONCO is offline
