-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   IMP 310 Rebuild/modification (https://www.offshoreonly.com/forums/restorations-upgrades/304673-imp-310-rebuild-modification.html)
ragman 11-04-2013 09:02 AM
1 Attachment(s)
Last pic for the day. We also had to make new pulleys for the engines.
[ATTACH=CONFIG]511808[/ATTACH]
chazfehn 11-05-2013 09:25 AM
This is such a cool project. Your doing everything the right way, keep the thread going and updated!!!! I'd love to do half the stuff to my boat!
ragman 11-05-2013 09:38 AM
3 Attachment(s)
Today there has been some work with the exhaust system. A lot of measuring and a lot of thinking to try to come up with something that’s a little bit different than usual :)
The beginning of the new exhaust ;)
[ATTACH=CONFIG]511871[/ATTACH]
[ATTACH=CONFIG]511872[/ATTACH]
[ATTACH=CONFIG]511873[/ATTACH]
ragman 11-05-2013 09:42 AM
Thanks a lot for your nice comments, much appreciated :)
Pliant 11-05-2013 12:25 PM
Very good stuff i envy your shop.
VoodooRob 11-05-2013 01:34 PM
I was just looking at your photos, you are really knocking this project out with some high end, one-off parts. Excellent machining on the aluminum. Just an FYI, one of your last pics is of your custom exhaust and the rear of the engine showing the crank with the flywheel bolts in it. Make sure to put extra, extra red Loctite on the flywheel bolts on Viper engines. The threads are tapped all the way thru ( you can see in the pan thru them) and oil will leak pass the bolt threads causing you problems. Just trying to help if you didn't know this, obviously your mechanical abilities are far above average.
ragman 11-06-2013 02:33 AM
Thanks for your comments and a lot of fun that you like our shop! :)
ragman 11-06-2013 06:05 AM
Wow! Thanks for those to kind comments! You made us blush over here ;)
I am aware of that issue with the bolts but big thanks for the heads up. Next time it’s maybe something that we overlooked. Thanks for showing interest. :)
ragman 11-06-2013 07:32 AM
1 Attachment(s)
Found another pic of the vents :)
[ATTACH=CONFIG]511924[/ATTACH]
32 Active Thunder 11-06-2013 09:38 AM
Threads like this help me get through the winter months
