Chris Craft 210 Scorpion RestoMod project WITH supercharged LS1 >
Old 06-23-2014 | 01:50 PM
Amazing craftsmanship. Give this man an old 38 footer.
hogie roll is offline
Old 06-24-2014 | 03:09 AM
Thank's guys.....
And on the subject of motor mounts...I simply used the LS -> SBC adaptors....normal stuff from the car world
https://www.dropbox.com/s/25oj9o1n51...2020.45.11.jpg
For some reason I can't see the picture?
Can you see it by clicking the link?
Juzzi
Juzzi is offline
Old 06-18-2015 | 05:17 AM
Its getting close to finish...
https://youtu.be/lOsocx3vmn4
Estimated launch within a week...
Juzzi
Juzzi is offline
Old 06-18-2015 | 04:10 PM
Really impressive both the craftsmanship and the motor. Any idea on the HP? Any concern with the drive handling the power? Congratulations!!
Feverz29 is offline
Old 06-18-2015 | 05:38 PM
Looks and sounds great!
Padraig
Padraig is online now
Old 06-19-2015 | 06:59 AM
Thanks!,
Since the drive is only alpha 1 I do have a big concern about the durability....the engine was from -98 corvette where the it made 615hp....and now it has bigger intercooler and almost non existing air filter so boost level might be increased from the 8-9psi what it had in a car...
Alpha 1 is only going to be used this summer and next winter the drive will be changed...the most common and easy option is bravo 1....I have already reserved one from 33ft scarab so that might be the way to go....I have also thought about alpha SS and blackhawk drive...but those are pretty hard to find.
So with alpha 1....I'm going to baby it to plane and NO jumping...it should hold for the summer since the boat is relatively small...
Juza
Juzzi is offline
Old 06-19-2015 | 01:53 PM
RSCHAP1's Avatar
Awesome
RSCHAP1 is offline
Old 06-19-2015 | 02:00 PM
SB
Juzzi
Now that, is a Hotrod !
Schweet !
SB is online now
Old 06-20-2015 | 11:24 PM
Sweet! Good to see another ls build. What great ratio drive are you gonna use? My ls project should be finished this week. I think we both will be very happy.!
250ekelly is offline
Old 06-22-2015 | 03:28 PM
The drive is normal small block unit so 1.5 ratio.
I'm having a little issue with the closed cooling system...the engine seems to overheat if I have thermostat in place...without it it keeps the temps 170-180 range in idle...but with it the temps rise to 240....and heat exchanger is still cold. It could just be a bad thermostat...even though it does open if I put it in boiling water.....weird...
Juzzi
Juzzi is offline
