Chris Craft 210 Scorpion RestoMod project WITH supercharged LS1 >
Old 06-23-2015 | 09:57 PM
Wow you already got the engine running??? Your fast! We did closed cooling on my friends check mate. The heat exchanger was mounted lower than the engine so we had a hard time getting it to cool right. Ended up being air pocket in cooling system. Used a air vac and filled it with vacuume and it works fine now. Idk how yr system is set up..
250ekelly is offline
Old 06-24-2015 | 02:26 AM
Hello Kelly,
Not "quite" that fast...I have been building this for five years... :-)
I also have closed cooling on my Ls project....if you can see the attached pictures the heat exchanger is the lower black tube one...the smaller "tube" is the combined steering and oil cooler.
Getting all the air out is a pain...I had to re-do the lower 'piping' since getting the air out of that U-shaped hose was impossible...I had to replace that hose with T-junction to get the air out. But even with that the system didn't work as it should have...but now without the thermostat it works fine.
If you look at the post #12 on this topic you can see a YouTube vid on the engine runnig.
Juzzi
https://dl.dropboxusercontent.com/u/...2019.19.37.jpg
https://dl.dropboxusercontent.com/u/...2019.31.49.jpg
https://dl.dropboxusercontent.com/u/...2019.31.56.jpg
Juzzi is offline
Old 06-24-2015 | 08:00 AM
Niicce set up that looks sweet. Have you had it out on water yet.
Old 06-25-2015 | 07:43 AM
Wow. Very impressive work!
apollard is offline
Old 06-25-2015 | 02:31 PM
clean install, very nice!
CDShack is offline
Old 06-26-2015 | 05:55 AM
First encounter with water is planned next week...wednesday probably...still have some upholstery work to do...and some fine tuning
.... tach is reading 1/4 of the real rpm and fuel press gauge is showing some weird error (digital gauge) and the same goes for wide band lambda...
Juzzi
Juzzi is offline
