Hinges
Is it a double hinge (piano hinge) that allows a (let`s say a back seat cushion) to first pull out then lift and tilt?
Would this do it?
http://www.stagebox.com/index.php?ro...product_id=407
Would this do it?
I keep thinking mine are like a Z and I think its these. Click on the blue hinge on the hunt hinge page and see if that isn't it.
http://www.hunthinges.com/products/s...eel-hinges.htm
http://www.ebay.com/itm/HUNTS-HINGES...-/400509464910
FWIW here is mine attached to the rear seat. I pull up in the front of the seat then pull out. Pretty much looks like a z I think you have to have the hinges like that if you use a double hinge with pins on same side (Like a U) it wont work..... Well I think any way. Maybe I'm over thinking this but best of luck on the project.
