Scarab Panther Engine Upgrade - Height Clearance >
Old 07-21-2015 | 07:44 PM
Default Scarab Panther Engine Upgrade - Height Clearance
Hi there,
Toying with getting a Panther and I'm concerned that the engines I would consider installing would be too tall to fit without modification to the lid (which I don't like). Has anybody fit something in the 27-31inch height into one of these? Merc 565 or 600sci?
Thanks,
marko88 is offline
Old 07-22-2015 | 08:29 PM
Rookie's Avatar
My standard NA 454 air cleaner bolts hit the bottom of my hatch when the hatch is closed. If you look at the hatch above the engine on the left, you can see the witness of the bolt.
Attached Thumbnails Scarab Panther Engine Upgrade - Height Clearance-twins.jpg
Rookie is offline
Old 09-09-2015 | 01:05 AM
Jesus ,6-7000k rpm ported 11.1 496's with some kamas that are supposed to be 10-15mph faster, should put you at max hull speed
anthonystempak is offline
Old 09-09-2015 | 01:08 AM
double hump heads 11.1 and rv cams don't make more than 400hp period.
Old 09-09-2015 | 07:25 AM
Rookie's Avatar
Was someone drunk posting last night?
Rookie is offline
Old 09-09-2015 | 12:59 PM
Also you need headers and over timing too the point of it won't start ,
Old 10-22-2015 | 10:05 AM
hullofjustis's Avatar
Originally Posted by marko88
Hi there,
Thanks,
blower motors will not fit under the hatch with carbs and flame arresters. with out mods. I raised the x dimension on mine but the company who did it put it to high and NA motors stick out 3 inches past the 2 inches i already raised the hatch. unfortunately I am dropping everything down a few inches this winter because it was so high it would not get on plane with out spacers in the drives
hullofjustis is offline
Old 10-22-2015 | 10:31 AM
We had hatches made that allowed for a high X and high-rise intake and large flame arrestor. You could also cut your hatches and allow the blower to be exposed...cool?
BenPerfected is offline
