SSM5 to #6 help
Old 12-30-2021 | 06:04 PM
No room to move engines up and forward. Extension box needed so a driveshaft can be used and engine can stay in place
ICDEDPPL is offline
Old 12-30-2021 | 10:39 PM
Did you buy the jig plates? Very nice, I think I read Glass Dave had some.
1Zoom is offline
Old 12-31-2021 | 10:55 AM
I`m borrowing them .
ICDEDPPL is offline
Old 01-19-2022 | 07:33 AM
Originally Posted by Unlimited jd
Ssm 6 transom assemblies account for a 13* transom angle.
I’ve never used the math measuring along the transom, I measure perpendicular to the running surface.
If you want the propshafts 2” below the bottom set the crank centerline measurement at shaft to shaft +2”. The boxes move the drive straight back, they look like they have rise in them, but that accounts for the 13* transom angle so the drives don’t end up lower.
2” above sounds like a good spot for them, the Old School top gun with a notched transom was 1” below the bottom, transom notched, no boxes and had no issues getting on plane. I was trying to talk Kevin into going up 2” with that setup when he had it.
OK ! I'll do it Jamie! I'll do it!
kreed is offline
Old 01-19-2022 | 08:20 AM
Make sure you calculate your driveshaft angle if can't move the engines, it may dictate how high you can go.
kvogt is offline
Old 01-21-2022 | 03:52 PM
Transom to propshaft is 5'.. that`s going to be out there ... these #6 things are heavy, gotta somehow mock this up on theboat
ICDEDPPL is offline
Old 01-21-2022 | 04:36 PM
F-2 Speedy's Avatar
Damn thats a lot of weight, Ive seen this setup on a 42 Tiger dont think Ive seen it on a gun
F-2 Speedy is offline
Old 01-21-2022 | 04:40 PM
Several top guns had 6’s on boxes. I had an album stored in one of my old phones of all the ssm 6 guns.
Unlimited jd is offline
Old 01-21-2022 | 05:26 PM
5’ from transom to leading edge of propeller?
IGetWet is offline
Old 01-21-2022 | 06:05 PM
To the end of the propshaft.
F6- Speedy, I`ll have my guy do the "racelayup" Glass Dave special on the transom
ICDEDPPL is offline
