427 SBC serpentine system >
Old 09-25-2025 | 04:42 PM
Default 427 SBC serpentine system
I am in the process of renovating my families 1979 Hallett Mini Day Cruiser with a new engine and stern drive. It currently has the original Mercruiser 5.7 260 with the gen 1 Alpha sterndrive. I have a new 427SBC being built which should be good for about 530hp/550tq. I am also replacing the Alpha system with a Bravo HP transom assembly and a Bravo 1XZ sterndrive. I now need to add a raw water pump to the front of the engine since the Bravo sterndrive doesn't have an internal pump. I have played with the idea of buying the whole serpentine system off the front end of a newer Mercruiser engine and installing it on the my new engine (mounting brackets, alternator, PS pump, raw water pump, etc). But... I don't know if this is even possible. What would be my best option here?
OGHallett is offline
Old 09-25-2025 | 06:13 PM
SB
Not much help from me, but there are tons of small block w/bravo drives built by Merc.
350mpi’s are one that ring a bell for me and they had serpentine belt drives.
SB is online now
Old 10-01-2025 | 10:05 AM
Thanks SB. I started calling around to see what 350MPI parts might work.
Old 10-07-2025 | 02:27 PM
I have pulled the engine and am working towards removing the Alpha transom assembly. I am a bit stuck though. Can anyone tell me how to remove the steering cylinder?
