Go Back  Offshoreonly.com > Owners Forum > Saber
What are you guys running for props (28's) >
Old 02-15-2012 | 11:15 PM
  #31
Keytime's Avatar
Originally Posted by Chris
running 30 pitch bravo/4 blades.
i have played with 3 blade vs 4 blades on other boats, not this one but i always thought the 4 blade was a better all around prop... just my .02
30's? Wow. What kind of power are you running?
Keytime is offline
Old 02-16-2012 | 01:26 AM
  #32
littledcsrodshop's Avatar
Chris' boat got lots a power..
littledcsrodshop is offline
Old 02-16-2012 | 01:38 AM
  #33
Originally Posted by martins custom marin
steve im running a 24 labbed on mine and doing 73 on the limiter we can hook up and give it a try on your boat before you purchase one. cwc you might of had someone work on it that didnt know how to do it right. i had my normal prop guy (for the cheap stuff) check the pitch on a prop, he tweeked it and polished to a mirror finish absolutly beautiful but i lost 6 mph he polished the cup out of it. send it to another place I would recomend bblades or dans prop shop
Out of curiosity what are you turning that engine ? I assume that's through a 1.5 ratio ?
Old 02-16-2012 | 02:15 PM
  #34
AIR TIME's Avatar
Originally Posted by AIR TIME
we had that happen one year in gerrys 46 turbine skater, we backed up from a card boat. poof prop came off 5 blade herring in 8 to 41 ft of water, depending on tide. but it was providence RI harbor. you can't see a foot in front of you, under water. we had a diver look for it, but the mud was so deep. he thought it sunk under it. we tryed a metal detector with no luck. play time two months.
oops it was 8 to 14 ft water not 41, on my boat been thinking of trying a p5 trans lifting prop.
AIR TIME is offline
Old 02-26-2012 | 08:34 AM
  #35
Biggus's Avatar
Artie, while in Miami, I spoke with several very experienced riggers concerning your boat. They all stated, you've got to remove the hook in the hull.
Biggus is offline
Old 03-01-2012 | 02:04 PM
  #36
AIR TIME's Avatar
nono no its rocker hahaha. thanks buddy. yeh that looks like my next stop. factory has been no help with cg either, so I am going to skip that. no reaon to find mine, when the guys who built it never took or adjusted theres. anyone know if this is a copyed hull , splashed hull. if so maybe I can find the cg from them. Kurt did you mean rocker. I do have a guy who will give me a price on that. it should be about 4ft to 6ft of rocker thats from the factory. should bought that 05 sutphen.
AIR TIME is offline
Old 03-01-2012 | 02:07 PM
  #37
Biggus's Avatar
....aahhh, yeah ROCKER! -Been on the road too long. They all said it will never run right with rocker and the weight.
Biggus is offline
Old 03-01-2012 | 02:12 PM
  #38
AIR TIME's Avatar
Red face
oh with the hp I have a bravo is not the ansewer, KONRAD BABY its bigger, meaner, and shorter. if the guy with the 31 sutphen didn't recut for twins, I would of paid the 14 gs and stripped the saber of its power and sold it. I know its bottoms are straight, no hook no rocker, no pads, not even a step. but boy that new OUTERLIMITS 29 running 97 with a 525 and 4 or 5 steps is BAD AZZ. hope to run that with twice the hp. later
AIR TIME is offline
Old 03-01-2012 | 02:49 PM
  #39
Stormrider's Avatar
JC Performance Engines
...boy that new OUTERLIMITS 29 running 97 with a 525 and 4 or 5 steps is BAD AZZ...
It's not running a 525. its a 600SC.
Stormrider is offline
Old 03-02-2012 | 12:19 PM
  #40
AIR TIME's Avatar
they were going to use a friends 525 for testing, was the talk a while ago. it was boxers spare motor. 600hp not dialed in yet 97 sweet. since boxer is putting custom power back in his old/ new 26 sutphen. the 31 he has runs 92 to 94 with 950hp. so if the bottom gets done I should be around a 100. my drive height at , propshaft worked great at 3''/4'' and 5'' got on plane easy with the 4 and 5 blades. if I only had a extra 100,000 kicking around I could of bought a 29 ol. boy 1100hp in one of them wow.
AIR TIME is offline
