Another question for Mike J or anybody who can help..
Hey Mike, you seem to be the expert around here on Scarabs..... I have a 38' sacrab (non-stepped) with 625's with 26" bravo's turning @ 5400. The props r turning IN. Should I switch them to turn out for more bow lift?? I would loke to pick up a couple mph. Boat feels little heavy in the bow...
Do you know anybody I can talk to who has properly set this boat up..
PS: its the same exact boat as Augie Penza's from Jersey
Iamfaster,i Seem To Keep Following You Around But I Have The Same Boat And Mine Turn Out Which I Was Told Creates Less Suction On The Back Of The Boat Which Frees The Boat Up,less Drag,more Speed!it Works For Me!try It,its Just Nuts And Bolts!good Luck
I think I will stay out of this one theres been a number
of different threads on this subject.
Try it, But remember docking and turning sharp will be different.
What trim tabs are you using???
What props???
What X Dim. ???
Mike J.
What props???
What X Dim. ???
Mike J.
Kent Perroux
02-18-2003 07:27 AM
