Predator Powerboats rebuilding a Scarab_38 >
Old 01-17-2012 | 04:25 PM
scarabman's Avatar
Have you gotten any more history behind the boat, and the large single step?
scarabman is offline
Old 02-20-2012 | 01:27 PM
The step was put there by the previous owner.
Activator put the step there.
noli is offline
Old 02-20-2012 | 01:33 PM
The windshield receiver is in place. The prep has begun for the paint job, sanding down the deck first, then hull sides.
The owner has designed the paint scheme.
noli is offline
Old 03-16-2012 | 08:49 PM
Hull prep at the shop
Sanding begins. Sander with vacuum suction 2-in-1
Attached Thumbnails Predator Powerboats rebuilding a Scarab_38-dsc_0534.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0535.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0541.jpg
noli is offline
Old 03-16-2012 | 08:51 PM
after sanding, the primer kote is laid down
The windshield template being made for personal fitting to the owner.
Then the acrylic windshield will be bent and wrapped around the cockpit
The black windshield is the template. Owner wishes to have the windshield's height lowered
bottom pic --> staggered engine config
Attached Thumbnails Predator Powerboats rebuilding a Scarab_38-dsc_0572.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0578.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0579.jpg
noli is offline
Old 03-16-2012 | 08:53 PM
aluminum dash panels and glassed seat shell
Attached Thumbnails Predator Powerboats rebuilding a Scarab_38-dsc_0584.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0588.jpg   Predator Powerboats rebuilding a Scarab_38-dsc_0595.jpg
noli is offline
Old 03-21-2012 | 08:42 PM
Originally Posted by noli
BTW, the body is all epoxy resin...solid!
That, being staggered, the fairings shape originally and the all flat deck not like on a 38KV is a sure tell-tale this is a LS 38 Scarab.
MikeyFIN is offline
Old 05-02-2012 | 12:14 PM
Hull is prepped for base coat paint:
Attached Thumbnails Predator Powerboats rebuilding a Scarab_38-imagejpeg_2.jpeg   Predator Powerboats rebuilding a Scarab_38-imagejpeg_2.jpg
noli is offline
Old 05-03-2012 | 10:25 AM
glassdave's Avatar
Neno the mind boggler
It actually looks like a giant Magnum Starfire with the rolled side scoops. That thing is gonna be bad azz! I am gonna sell my 34 and step up to a 38 Excel end of this summer. Looking for an 88 or 89 with TRS (so i can go Konrad).
08 OPA High Points Champion
glassdave is offline
Old 05-08-2012 | 03:01 PM
The beginnings of the paint
noli is offline
