Back from the Dead; '81 Scarab 38 Resto
#141
It was the only 'fuel gauge' I've ever trusted.
RR
#143
Charter Member#568
Sorry about the bad pic but it's all I have for the time being. Here it is with all the new fittings and hose. 1 extra opening which is capped, 3 in use. If I wanted to be able to transfer fuel between tanks that would use up the extra. The power steering tank has the sight tube (which needs replacing) like Rak mentions.
Straight bottoms and flat decks
#145
Charter Member#568
Cool. Thank you. You'll still have to wait to find out about the fitting though. SB likes a challenge and I don't want to ruin it for him. I'll bet you a drink this summer that the system was on the boat back when you were on it. You probably used the thing.
#146
Not really, I just don't like waiting for an answer...so, if that is what it takes to speed up the process, so be it. LOL.
#147
Charter Member#568
Ok. The gauge shoots a puff of air through the fitting to the bottom of the tank through the 1/8 tubing. It measures how much pressure it takes for the air to equal the weight of the fluid. Based on this reading it knows how many pounds of fluid are in the tank. You can get cards for the gauge face that convert the lbs to gallons of any liquid you want to measure- gas, diesel, water.
The 4 buttons on the left select the tank you want to measure, the button on the right pumps the air. All manual, no electric.
#148
^^^Never would have guessed,
#149
Holy hurricane how cool, but never saw such a measuring tool/instrument! Why is it not well "acceptable" because of potential syphoning should the line be compromised? And yes is the drink a bloody? LOL
#150
Charter Member#568
Yes, the siphoning potential is the issue. However, it exits the top of the tank, has a loop in it, then continues to the upper dash where it has another loop. It never drops below the top of the tank, or even close to the top. I don't believe it's a cause for concern.
