Bought this 31 Thunder, few questions. >
Old 10-21-2017 | 11:58 AM
Will need hydraulic steering to fix that. There are a lot of factors to cause that. Like which prop is loaded more while running at that particular moment.
90viper is offline
Old 10-22-2017 | 09:57 AM
Originally Posted by pullmytrigger
I also find if I let go of the wheel anytime on plane the wheel will turn all by itself hard to the direction the wheel is off center right to the lock if you dont stop it. So if you're slightly turning left the wheel goes left. If you're turning right the wheel goes right. Not good if you're going 60. My Donzi or Fountain never did that. It has the stock merc power steering. I do find the steering super easy to turn lock to lock, like one finger easy. Way easier than any other boat Ive been in. Is there something you can tighten?
My 91 excel with factory hydraulic steering was like that, drove that boat with your fingertips. The steering was very sensitive and boat responded to the slightest wheel movement. I recall resting my arm firmly against the side of the bolster as a steady rest when steering with one hand because the wheel offered zero resistance.
dandercam1 is offline
Old 10-22-2017 | 10:02 AM
None of Mine have not done that. Do you have piggy back hydraulic steering which does not have a hydraulic helm?
90viper is offline
Old 10-22-2017 | 10:28 AM
Yes the 91 I use to own had piggy back hydraulic steering from the factory. My 89 excel and my fountain both have full systems with the hydraulic helm. Totally different feel, Hydraulic helm gives a much tighter steering feel.
Old 10-22-2017 | 04:34 PM
Piggy back??
pullmytrigger is offline
Old 10-22-2017 | 06:07 PM
Piggy back is external steering rams but does not have a hydraulic helm. Not sure how it is done for I have not owned a boat with it
90viper is offline
Old 10-25-2017 | 03:46 AM
Piggy back??
Do you have hydraulic rams on the outside of the transom attached to the outdrives?
Old 10-25-2017 | 08:23 AM
No
Old 10-26-2017 | 10:02 AM
No
Ok then that's just standard power assist steering. I would at least add a tiebar between the drives if it doesn't already have it. Piggy back external hydraulic setup is a nice upgrade if you come across a clean used setup. Not really necissary until you run over 75 mph or so.
Old 10-26-2017 | 03:59 PM
Yeah it has a tie bar. Hmmmm Ive had other boats with Merc power steering and they didnt do that. Maybe that is how it is supposed to be lol
