Spy pics of the new Doug Wright 38
#111
Originally Posted by dcrighton
SK190
Another thing that a spray rail does is act as a stiffener/stringer to strengthen the hull sides-if its layed up right. MTI may not have a spray rail but he does put a stringer on the inside of the hull in the same location. One of the reasons that the Quatar boat may have "come apart at the seams" is that alot of boat builders don't put coring at this point in the hull. They put it above and below with nothing but a thick layer of glass at the bottom of the spray rail. Strength is also a function of the thickness of the composite and this would dictate that it would be the weak point if it had no coring.
MAXIMUS AND I HAVE VERY LIMITED RACING EXPERIENCE, I HAVE THREE P CLASS RACES BUT WE SURE HAVE SEAT TIME IN CATS. WITH THE EXTRA SET OF ENGINES WE PLAN TO REALLY RUN THE BOAT. I ALSO PLAN TO SPEND A TREMENDOUS AMOUNT OF TIME WITH JOHN IN THE BOAT DIALING THE BOAT IN.
WE ARE BOTH LOOKIN TO HAVE A GREAT TIME, THE STOCK CLASS IS A GREAT GROUP OF RACERS! I HOPE MY BOAT IS READY FOR MIAMI!
DAN
#112
Like others have said, glad to see someone else has stepped up to the plate to bring some competition to the twin O/B cats. For a 32 to run those speeds is simply incredible. I have heard AMT's are rough water boats, but to run over 110 in a 32 with twin 2.5's is also a great acomplishment.
#113
Did Gary's boat get added weight because it was under the required minimum or just because it was to fast? What is the weight for a 32'? I know some of the 28' skater pleasure boats are under 3600lbs. That is one reason they can run 120mph
#114
#115
Dan,
Do you have any photos from when the boat was being laid up at Doug's shop??? If you got them I would love to see them along with everyone else I am sure.
#116
When Gary's boat was built SBI didn't have weight rules. When he killed the field at his first race is when the class called for added weight. Now it is 125# per foot. A 28' would have to weigh 3800# I think a 30' is 4050# and a 32' 4300#
#119
Ryan,
I am sure you have taken a ride in the Doug Wright 32'. Other then length what advantages would you say that boat has over the original design that you race now????
#120
Besides the obvious the 32 has different strake configuration, wider tunnel with more aggessive angle of attack, 4.5 steps instead of 2, cg is moved further forward
