How Can I Get A McGard Prop Lock OFF ???? >
Old 05-03-2006 | 04:48 PM
Strip Poker 388's Avatar
Angry How Can I Get A McGard Prop Lock OFF ????
I am SOL .I was trying to take the prop off and the teeth on the lock itself broke off The key is fine.Is there a trick besides a torch,air chisel or cut off wheel to get them off ?
With out damaging the threads of the shaft
Thanks for any suggestions.
Attached Thumbnails How Can I Get A McGard Prop Lock OFF ????-aaaaaaaaaaaaaaa-005-large-.jpg
Strip Poker 388 is offline
Old 05-03-2006 | 04:53 PM
Dean Ferry's Avatar
Veteran: Air Force
Default Re: How Can I Get A McGard Prop Lock OFF
Rob,
I would say that the cut-off wheel is probobly the way I would go, you can cut it ~50% on 2 sides and then try to GENTLY pry to 2 pieces of the nut off the prop shaft! Man, that really sucks, it gives new meaning to THEFT -PROOF!
Good luck,
Dean
Dean Ferry is offline
Old 05-03-2006 | 05:00 PM
Boomer 880's Avatar
Tap a large socket over the lock, and turn off. It might trash a socket, but it should grip enough to remove.
Boomer 880 is offline
Old 05-03-2006 | 05:08 PM
Thanks Dean..
What about the Stainless ring/collar that surrounds the lock nut ?? I believe the nut is brass??? I was thinking the air cut off wheel would be to big to get in there??
Old 05-03-2006 | 05:18 PM
JnT's Avatar
JnT
Try a Dremel tool and cut it off.
JnT is offline
Old 05-03-2006 | 05:58 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Wink Re: How Can I Get A McGard Prop Lock OFF ????
Paint the prop gold, and set it on the street corner. I am sure there are some fine young men in Jackson to remove it for you
Sorry for your misfortune Rob Are you going to PicWick?
WARPARTY36 is offline
Old 05-03-2006 | 06:19 PM
Default Re: How Can I Get A McGard Prop Lock OFF ????
I used a dremel to cut off mine when I lost the key. Like Dean said, cut it down each side and pry it off.
Magic Medicine is offline
Old 05-03-2006 | 06:29 PM
fountain1fan's Avatar
plazma cutter
fountain1fan is offline
Old 05-03-2006 | 06:42 PM
MitchStellin's Avatar
Can't ya get one of your chicks to suck it off The brass nut is soft, I would try the socket over it first, it sounds much easier than the cut off wheel. Does it have a nylon insert, like a lock nut? If so you could melt that out and it might turn easier. The best way is to drop the lower, remove the prop shaft and replace the prop and the shaft and be done with it.
MitchStellin is offline
Old 05-03-2006 | 06:57 PM
isn't today your day off
open87 is offline
