Borg Warner C72 Operating Pressure ? >
Old 05-02-2006 | 06:51 AM
Scarab3DMC's Avatar
Default Borg Warner C72 Operating Pressure ?
I just rebuilt my Borg warner C72's...and I want to add trans oil pressure gauges..(reccomended by Marc @ Bam)...whats the range ?? 0-80..0-100 ??
Scarab3DMC is offline
Old 05-02-2006 | 06:56 AM
RMPRam's Avatar
Default Re: Borg Warner C72 Operating Pressure ?
I have them on my Huber 1450's and they run 155 lbs.
RMPRam is offline
Old 05-02-2006 | 08:34 PM
Interesting... I put temp sensors on mine because I fear over-temp condition. is it more important to watch pressure??
jackhammer is offline
Old 05-03-2006 | 08:26 AM
Scarab3DMC's Avatar
Pressure is more important...thats what Bam told me...
Old 05-03-2006 | 10:08 AM
Mbam's Avatar
Offshoreonly Advertiser
Use a 200 PSI gauge. Yes, pressure is more important. If you have enough cooler (we recommend 2x8 bundle) if they get hot they are already dead. Fluctuating pressure (#1 cause of failure) can indicate low fluid level before any damage is done.
Mbam is offline
Old 05-03-2006 | 11:36 AM
Scarab3DMC's Avatar
Thanks Marc...
Old 05-27-2006 | 07:31 PM
Scarab3DMC's Avatar
what is normal operating pressure ??...at idle I have 50-60 psi running its 110-125...is that OK ??
Old 05-28-2006 | 06:28 AM
Scarab3DMC's Avatar
anyone ???
Old 05-28-2006 | 09:45 AM
Mbam's Avatar
That's low. We won't ship one that won't hold 80 PSI @500 rpm hot. Pull the regulator apart and see what color spring is in it. Should be black. There is a white spring that was used for a while in an effort to drop the pressure (therefore less power used to turn the pump) but experience has shown that you do need more preesure.
Mbam is offline
Old 05-28-2006 | 07:12 PM
Scarab3DMC's Avatar
More headachs..Marc...reverse on both trans won't engauge after I run awhile....on a cold start they shift fine...but its tough trying to manouver around without reverse...linkage is set to forward and reverse detents...I have to shift into reverse then netural then back to reverse...sometime they engauge...sometime they don't..pressure still a issue ??..what should I read when in forward @2500 rpm...always @100 psi..now...I wish I would have sent them to you...any ideas about reverse ??...do you think the power valves are bad ??THANKS FOR ALL THE HELP.....Dave..
