Turbine 101 >
Turbine 101
Turbine 101
Old 09-22-2007, 08:52 AM
KNOT-RIGHT's Avatar
Default Turbine 101
TURBINES IN A BOAT!
Hello to all my Skater brothers!
After all the hard work I put myself through.
I realize that most of you must think that I should seek counceling.
Well I am! 12 ounces at a time
Heres the plan.
Remove two good running PSI Blown chevys.
INSTALL TWO MARINIZED LYCOMBING T53,s L13B,s TURBINES in a 46 SKATER.
PROJECTED TOP SPEED 180MPH+
I took one final picture of the piston engine installation.
The removal takes place today!
Lets have some fun!
KNOT-RIGHT is offline
Old 09-22-2007, 10:05 AM
Comanche3Six's Avatar
You always have the most interesting projects!
Ed
Comanche3Six is offline
Old 09-22-2007, 10:34 AM
KNOT-RIGHT's Avatar
Everything disconected and ready.
Gotta love how easy it is to work on these cats.
Just waiting for a xtra set of hands.
Old 09-22-2007, 10:44 AM
1CE
Default met u @ Fall River poker run
Heres the plan.
Remove two good running Blown chevys.
Install two marinized t53 L13b turbines.
Lets have some fun!
Gerry/or/Jerry (1st 1 I believe). Anyways I was on Paul's 33-Sutphen "Outrageous" @ F.R. (the orange boat next to u-guys). Thanks for all the pics from yourself and Art. "Airtime" I think u-are correct a 30 pack may not even cure your endless desire to drive yourself beyond reasonable decision making best of luck jay "1CE"
1CE is offline
Old 09-22-2007, 11:22 AM
KNOT-RIGHT's Avatar
Ed
Ed, your not that far away. The next time your heading this way stop by!
Theres plenty of fridge in the beer.
Old 09-22-2007, 11:31 AM
KNOT-RIGHT's Avatar
Whaz up???
The next poker run I gotta bring more beer Atleast two coolers
after the run Pete Nopper pretty much cleaned me out.
Say hi to Paul for me!
Why dont you guys stop by also I have the video here.
Not the best video however there is some decent footage of
outrageous.
Here is a picture of the Caliper controller.
This is activated by a micro switch in the shift which sends voltage to the coil and the onboard air system will apply air to the cylinder which mechanicaly pushes the master cylinder which squeezes the caliper stoping the N2 on the turbine enabling a shift in and out of forward neutral reverse.
Old 09-22-2007, 01:26 PM
Hello Gerry
Thanks for the invitation! Too bad I wasn't close by today, I could operate the backhoe.
Ed
Old 09-22-2007, 03:03 PM
KNOT-RIGHT's Avatar
Motors out!
Old 09-22-2007, 03:13 PM
Knot-Right, the name couldn't fit any better!!!! Great thread, I liked the first build, I think the next build thread will be even better. Good luck on the conversion, if I was closer I'd help ya with the beer, and the project.
bobkatz is offline
Old 09-22-2007, 03:57 PM
In the end, you will be far better off doing this than you could imagine.
It just takes one major concern off your mind when boating.
Boatlesss is offline
Quick Reply: Turbine 101
