new progress on 2500 hp 2 speed transmissions >
Old 01-07-2008 | 08:57 PM
BigSilverCat's Avatar
Default new progress on 2500 hp 2 speed transmissions
finally have the first two off the transmission dyno and ready to put in.
Attached Thumbnails new progress on 2500 hp 2 speed transmissions-1-resize.jpg   new progress on 2500 hp 2 speed transmissions-2-resize.jpg
BigSilverCat is offline
Old 01-07-2008 | 09:36 PM
1CE
NIIIIIIIICE, U-buildem ?
1CE is offline
Old 01-07-2008 | 09:46 PM
FREEDOM US1's Avatar
Skater Brother
I could not get transmissions to hold together in Freedom US1 46 Skater. You can try them in my boat. If they hold up for a few rough water runs you have a winner. I think the high performance boating community could use something like this. Good Luck!!!
FREEDOM US1 is offline
Old 01-07-2008 | 11:14 PM
masher44's Avatar
motors look a little familiar
masher44 is offline
Old 01-08-2008 | 07:53 AM
DirtyMoney's Avatar
Very nice.
DirtyMoney is offline
Old 01-08-2008 | 08:00 AM
Put a set of those badd Boyz in the Freedom US1 46 Skater for R & D , and Jimmy will test them better then that dyno will ever do ... lookin good
Old 01-08-2008 | 10:51 AM
CcanDo's Avatar
Has the case design changed from earlier pictures ?
The input shaft design appears similar to that Borg Warner uses. However, relative to overhung load, bell housing alignment and drive plate durability, should an input shaft nose rod fit a crankshaft pilot bearing ?
Your pictures convey a very sanitary assembly.
CcanDo is offline
Old 01-08-2008 | 12:04 PM
Are those attached to buddyoo's big hp diesels???????
Old 01-08-2008 | 02:21 PM
thats pretty funny.
Old 02-01-2008 | 03:10 PM
cougarman's Avatar
Looks pretty nice, have any more info to share with us ?
Jon
cougarman is offline
