whats a "rev kit" ??? >
Old 04-09-2005 | 01:32 PM
Default whats a "rev kit" ???
Ive heard this from time to time ususally referring to small block chevys.......what exactly is this ???
pullmytrigger is offline
Old 04-09-2005 | 03:54 PM
articfriends's Avatar
Default Re: whats a "rev kit" ???
Its a set of "booster" springs that go between the cylinder head and mechanical roller lifters so the lifters stay in contact with the cam at high rpm's without running extra valve spring pressure. 10 years ago someone tried this on hyd roller cams and was marketing a package for small block chevy's,i don't know if it ever caught on,haven't heard much about it in a few years,Smitty
articfriends is offline
Old 04-09-2005 | 04:04 PM
redfountain420s's Avatar
here are some pictures of a 350 roller motor with a rev kit , the rev kit are the springs on top of the roller lifters and against the gold plate under the head . from what im told they keep the roller lifters in better contact with the cam. i hope this helps
Attached Thumbnails whats a "rev kit" ???-350-roller-mtr-1mod.jpg   whats a "rev kit" ???-350-roller-mtr-2mod.jpg   whats a "rev kit" ???-350-roller-mtr-3mod.jpg
redfountain420s is offline
Old 04-09-2005 | 04:51 PM
Vinny P's Avatar
I hate the winter!!
Rev kits are mainly used on solid roller cams. Their main purpose is to keep the lifter from bouncing off the cam on the cams base circle. Basically, it keeps a small amount of spring pressure on the lifter when the valve is closed.
Vinny P is offline
Old 04-09-2005 | 05:42 PM
thanks for the replies guys.........a motor that turns what rpm should have one of these????......or do people still use them???
Old 04-09-2005 | 05:59 PM
Vinny P's Avatar
I hate the winter!!
In my opinion, rpm is not the determining factor. I would run one if I had a solid roller cam. As I said, it keeps the lifter on the base circle of the cam during valve lash. On a hydraulic cam, the lifter is held done by the oil in it.
Vinny P is offline
Old 04-09-2005 | 06:40 PM
oh.....just thought by the name "rev kit" it was a high rpm thing......
Old 04-10-2005 | 09:35 PM
Official OSO boat whore
One of the big purported advantages was that it allowed for lower valve spring pressure so the rockers would live. I thought the kits were built by Air Flow Research. They may still have them. As strange as it may be, I've never heard of a kit being produced for the big block chevy.
Cord is offline
Old 04-11-2005 | 10:27 AM
I used to run them on Big Blocks several years ago, One set I had was a crane and the others where made by Jomar I believe. They were used a lot in drag racing and truck pulling on engines with real heavy valve train components. I believe the circle track guys also use them because they will keep the lifter in the bore and on the cam if you break a rocker, etc.
AfterHours is offline
Old 04-11-2005 | 10:50 AM
Brad Zastrow's Avatar
I had rev kits in my 572's. They are very hard on cams. Too much spring pressure for long term use. I was told after I broke a cam they are best in high rpm applications like drag racing.
Brad Zastrow is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
BLee
07-24-2003 07:57 AM
mikesufka
12-26-2002 11:23 AM
JaayTeee
Baja
28
12-09-2002 08:51 PM
