Consensus on Drive Lube??? >
Old 04-14-2005 | 09:53 PM
DrNautica's Avatar
Default Consensus on Drive Lube???
OK.
I bought a case of Amsoil AGM (Marine Gear Lube) but the rating on the bottle is ambiguous. It says GL-4 and GL-5. So which rating does it really have?
Also, how well (and with what) should a drive that previously used Merc HP be flushed. Actually, the drive is new but came filled with the green stuff. Are there any issues with mixing the Amsoil with the residue of the Merc green after draining?
Sorry for the resurrection of the drive oil thread but I'm still looking for a Consensus.
DrNautica is offline
Old 04-15-2005 | 11:12 AM
Wobble's Avatar
SORE MEMBER
Default Re: Consensus on Drive Lube???
Originally Posted by DrNautica
OK.
Good luck with that.
I run the Red Line I just let the drive drain for 24 hours but move it all the way up for an hour then back down. Seems to get the most out. 50 hour changes.
Wobble is offline
Old 04-17-2005 | 09:15 PM
AMSOIL AGM (Marine Gear Lube) is completely compatible with PAO, PAO/Ester, Petroleum and Petroleum/Synthetic blends.
Kevin Dinwiddie CLS
AMSOIL Inc.
launchit is offline
BowenCT
Drives and Lower Units
2
09-12-2008 03:22 PM
1 MAIDEN AMERICA
2
11-05-2007 07:42 AM
nordic95
5
11-23-2006 05:06 AM
