Bravo hinge pin tool >
Old 04-15-2005 | 07:29 PM
epeek's Avatar
Angry Bravo hinge pin tool
Does anyone know what size tool is needed for a bravo
hinge pin? I ordered all my bellows & swivel pin...
and a hinge pin tool. All showed for this weekends
project,except the hinge pin tool. Now Im screwed.
Any Ideas??
epeek is offline
Old 04-15-2005 | 08:11 PM
ali
Smile Re: Bravo hinge pin tool
No prob>>> 1/2 hex wrench and 1 cold brew
ali is offline
Old 04-15-2005 | 08:23 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Bravo hinge pin tool
Yep, used the 1/2" allen wrench many times on this. Don't for get to use locktite and torque it when reassembly.
US1 Fountain is offline
Old 04-15-2005 | 09:22 PM
epeek's Avatar
Thanks guys. Now all I need to do is find a 1/2 inch
allen somewhere.
epeek is offline
Old 04-15-2005 | 09:32 PM
Ginger or Mary Ann?
Just get the allen wrench and cut the short leg off with a cut off saw and use in a 1/2" socket. Wa La!
Old 04-15-2005 | 09:45 PM
Ted G's Avatar
Be careful if you use the allen. If it doesn't come easily, don't twist till it strips. The tool will do a better job than the allen if they are sticky. I stripped one with an allen, then got the others with the tool no problem. Then we used an easyout on the stripped one, but it was trashed at that point.
www.cbpba.com
Ted G is offline
Old 04-15-2005 | 10:28 PM
ali
Any sears store will have it.
ali is offline
Old 03-30-2023 | 07:16 PM
Default Helicoil
Anyone have the part number and the size for the threads? I have the same issue on my Bravo 3. Part number for the hill coil kit would be great. And what size drill.
Tricountytrail is offline
Old 03-31-2023 | 08:29 AM
Active Streak: 30 Days
They are all over Amazon. Also, you may have to heat up the pins to get them out if they were installed correctly the last time. Might as well plan on putting a heli-coil or two in also. Use red loc-tite when installing the heli-coil too.
Helmwurst is offline
Old 03-31-2023 | 08:38 AM
I'm looking in my old orders for the bit size, but not finding it. It should be on the helicoil website.
I have it out in my shop if I get a chance to find it before someone else posts the size.
https://formulaboatsforum.com/VBFORU...repaired.8597/
SabrToothSqrl is offline
