That purple wire.... >
Old 04-16-2005 | 08:09 AM
ctadams21's Avatar
Default That purple wire....
I've read that you need to ground the purple/white wire to set the timing on merc engines.
Is this only the case on the efi engines? I have a carbed HP500 with TB IV ignition.
CTA
PS-need v8-22 module,anybody?
ctadams21 is offline
Old 04-16-2005 | 09:20 AM
hillbilly24's Avatar
Default Re: That purple wire....
You should groung the wire before starting engine to set timing or adjust carb then shut down before detaching.
hillbilly24 is offline
Old 04-16-2005 | 02:45 PM
On a TB IV, you don't have to gound anything, just on TB V's.
Griff is offline
CigDaze
07-20-2006 02:04 PM
ALL IN
Fountain
3
04-27-2006 09:15 PM
waybomb
1
02-12-2006 10:17 PM
AWELSH
1
04-10-2004 04:01 PM
Hotfoot
05-14-2003 04:23 PM
