Impellers that dont burn out >
Old 04-18-2005 | 10:14 PM
JCPERF's Avatar
Default Impellers that dont burn out
Found a company at Zuls today that makes sea pump impellers that can run dry and not burn the blades off the impeller.Its a company called Globe Marine.The impeller looks like a Mercury impeller but is blue.It has a special coating on it.Not that expensive either.
JCPERF is offline
Old 04-18-2005 | 10:17 PM
Default Re: Impellers that dont burn out
sold!!!!!!
dreamer is offline
Old 04-18-2005 | 10:18 PM
JCPERF's Avatar
Originally Posted by dreamer
sold!!!!!!
After me.Should go like hotcakes cant find a site for them yet
JCPERF is offline
Old 04-18-2005 | 10:22 PM
Tricky919's Avatar
I'm in...........
Tricky919 is offline
Old 04-18-2005 | 10:23 PM
JCPERF's Avatar
Will have a pic of it and the box it comes in tommorow
JCPERF is offline
Old 04-18-2005 | 10:24 PM
Tantrum's Avatar
In! Twice.
Tantrum is offline
Old 04-18-2005 | 10:28 PM
Sydwayz's Avatar
Forum Regulator
They have been around for a while. Your engine will run 8-15* warmer with a Blue Globe over standard Merc impellor. I am pretty sure they have some type of teflon/silicon to their construction. Do a search; has been info on them in the past here on OSO.
Sydwayz is offline
Old 04-18-2005 | 10:40 PM
Ted G's Avatar
Bevery careful with the Globes. They are softer and more flexible that stock impellers. They will run hotter due to lower flow and they have been found to have problems in engines that see extended high RPM usage. I just had one fail on me and it looked perfectly fine, just wouldn't move water. If your engine is basically stock it should work fine, and they wil run dry with no burn out.
www.cbpba.com
Ted G is offline
Old 04-19-2005 | 05:36 AM
East Coast B's Avatar
I'm in! Post a website or number if anyone finds one?
East Coast B is offline
Old 04-19-2005 | 05:41 AM
http://www.globerubberworks.com/nav....ducts_impeller
