Impellers that dont burn out >
Old 04-19-2005 | 06:31 AM
scottc's Avatar
Default Re: Impellers that dont burn out
Had them in my old boat. Will never use them in anything else. Both failed in less than 10 hours.
scottc is offline
Old 04-19-2005 | 06:46 AM
Poorsche's Avatar
Too Old has some impellers that will run dry for 24 hours--Globe says 15 minutes if I read data sheet correctly.
Poorsche is offline
Old 04-19-2005 | 07:04 AM
Ed
Smile Re: Impellers that dont burn out
Have been using the blue "Rubber Works" impellers since the early eighties, when they first came to the marine market. Do not recommend using them on any outboard of any kind. They are too soft & at mid R.P.M. range & up, they do not provide the volume. Plus they do not last. They do last a bit longer in inboards & sterndrives due to their over-all lower R.P.M. use. Stick with Mercury brand. My .02. Ed
Ed is offline
Old 04-19-2005 | 08:19 AM
SCRAPMAN1's Avatar
I Tried Them In My Hustler And Had Nothing But Problems. All 3 Motors Ran 20 Degrees Hotter And After 10 Hours Or Less They Just Quit Moving Water. I Pulled Them Out And They Still Looked Great. They Make Great Paperweights For My Desk Now.
I Figured Out That If You Dont Run Your Engines Dry, The Merc Units Work Pretty Good! :d :d
SCRAPMAN1 is offline
Old 04-19-2005 | 10:46 AM
LIOPA's Avatar
Hey JC......I need a price on some work.......call me at 631-724-8707
Thanks,
Paul
LIOPA is offline
Old 04-19-2005 | 10:56 AM
Reckless32's Avatar
Rough Seas Lie Ahead
When would you change them? Annually like the current ones should be to be safe? Bi-annually putting faith in them?
I think I'll stick with the ones I have and stay with my routine of annual replacements. It leaves me with a good feeling, especially if I'm on a run taking me 100 miles from homebase....
Reckless32 is offline
Old 04-19-2005 | 10:59 AM
wwwTOPDJcom's Avatar
and Im sure no water to your engine for 15 minutes would be good?
wwwTOPDJcom is offline
nocigarette
Classic Offshore
90
05-14-2026 12:41 PM
jima97
4
07-04-2008 12:26 PM
deboatmon
7
09-19-2003 08:43 AM
zoomba
4
10-14-2002 09:40 PM
THRILLSEEKER
23
10-08-2002 07:06 AM
