260 Legend 7.4 Mpi Prop?
CAN ANYONE WITH A 280 LEGEND WITH A 7.4MPI(310HP0 TELL ME WHAT PROP THEY RUN? bOAT HAD NO PROP WHEN I GOT IT. Have a 21 mirage plus on and it needs more rpm like 300-350 more rpm. Thanks!!
max rpm on a 7.4mpi should be 4600rpm if you have a 21 and your are turning 4300rpm at wide open throttle then you need to go down to a 19 pitch and that should bring the rpms up about 200 to 250 .
before you do that make sure the throttle linkage is adjusted right and its opening the throttle plate all the way.
good luck
good luck
Check on Ebay you should be able to pick one up between $150 to $250.
And boatnt you are correct on the Mirage Plus it is cupped v.s. the standard is not.
