For all you TRS guy's
Old 05-13-2005 | 08:26 PM
Papache's Avatar
Registered User
Default For all you TRS konrad guy's
I make stand off boxes for trs drives the boxes sell for $4000 for the pair. Comes with studs and gaskets, drive line is separate, can modify yours . The boxes are 9 degrees to the transom and 12'' long ,we can can make any type of spacers needed email kidapache2000@yahool .com The twin trbo vet does not come with them.
Papache is offline
Old 05-13-2005 | 11:28 PM
Default Re: For all you TRS guy's
Where are your pics?
Byrdman is offline
Old 05-15-2005 | 11:01 PM
Papache's Avatar
Registered User
the pics are on
Papache is offline
Old 05-16-2005 | 08:21 AM
Waterfoul's Avatar
Gone Fishin'
Uh oh... looks like a classified in the GD section!
Waterfoul is offline
Old 05-16-2005 | 11:30 PM
phughes69's Avatar
What is the thickness of the material and what kind of material did you use? Are all the threaded holes helicoiled?
phughes69 is offline
Old 05-17-2005 | 10:50 PM
Papache's Avatar
Registered User
1/2 thick thread inserts with studs that lock in
Papache is offline
Old 05-18-2005 | 06:44 AM
so , how much height is that going to give , my trs is set up with the propshaft even with the keel (single)
open87 is offline
Old 05-20-2005 | 11:24 PM
Papache's Avatar
Registered User
Originally Posted by thayes11
Does that box mount on the transom and sit 12" back? when someone mounts there TRS how do you make up the shaft diffrence in the shaft to the transmission, you need 12" coupler? is that included????
yes they are 12'' the drive line is separate i need your old one to modify yours to make it work the box bolts to the transom
Papache is offline
Old 05-25-2005 | 11:19 AM
p4-33's Avatar
Papache, how to the internals bolt up? Can you still use a plug-in tailstock, or do you need a drive-line with a flange on the output? How does the drive engage? Does the drive yoke engage with a female spline?
I don't see any access panels, so that must mean that all connections are made either inside the transom or from outside the gimbal. Does the box have an internal shaft that is supported with carrier bearings? Please explain.
Now, if we could just get the raised x-dim problem solved without having to jack up the motors, we'd be in biz!
Thanks,
Brian
p4-33 is offline
Old 05-25-2005 | 11:49 AM
JCPERF's Avatar
Looks a little Fly by night to me
JCPERF is offline
