bravo 3 problem
i bought a 1995 formula w/a bravo 3
when i put the boat in today it goes in reverse when i put it in forward and reverse when i put it in forward
someone told me that the cable is not installed right on the dash controler
can give me some adivce how to repair
thank you
thank you
pull the shifter out and you will see two throws that the cable could be atached to, hook it to the other one. I don't believe they make counter rotating props for bravo III's since its's kind of a mutt point, so you cant just switch the props. I wonder how the hell it got the way on a 95' ?
