Bravo One Problem >
Bravo One Problem
Bravo One Problem
Old 08-19-2007 | 05:57 PM
scottw's Avatar
Default Bravo One Problem
I was coming into the bulkhead at the ramp and threw a person a rope on the dock. I turned the wheel to the left and went to pull the transom around. As this happened the boat began to back out and I reached for the shifter and hit the throttle. I think the rpm's were under 2000 and I reached again and threw it in forward. I heard no negative banging or anything but now I have no forward. When in reverse I have to go past neutral to get it to disengage but even with the shifter all the way forward still won't go into forward. Do you think I broke something or is it just a linkage problem. How can I diagnose the problem?
scottw is offline
Old 08-19-2007 | 06:00 PM
Probably broke the cone clutch or the floor out of the forward gear.
Griff is offline
Old 08-19-2007 | 06:30 PM
scottw's Avatar
Unhappy
is there anyway to put drive into foward without using the linkage to check to see if the linkage casing moved. I'm in internal damage denial.
scottw is offline
Old 08-19-2007 | 06:56 PM
Tinkerer's Avatar
Probably bent a shifting fork or stretched the linkage.
Tinkerer is offline
Old 08-19-2007 | 09:16 PM
It's easy enough to pull the rear cap and work the linkage manually.
Rene
oldandtired is offline
Old 08-20-2007 | 06:22 AM
fastlane40's Avatar
Disconnect the shift cable that goes to the drive from the shift point on the motor.Push it in or pull it out and see if it engages foward and reverse.This will tell you if the problem is in the adjustment of the cable.Hope this helps.
fastlane40 is offline
Old 08-20-2007 | 07:56 AM
Mr Gadgets's Avatar
Charter Member #601
Do what fastlane said.. If that doesnt work, pull the back cap and look for problems..
Mr Gadgets is offline
Old 08-20-2007 | 09:00 AM
Default Bravo
Never shift a Bravo above idle. It's instant death.
deboatmon is offline
Old 08-20-2007 | 08:38 PM
scottw's Avatar
Thanks for all the help. I'm going to try pulling the linkage off and shift by hand. I'll let you know how I make out.
scottw is offline
Old 08-21-2007 | 02:54 PM
Underneathe the forward gear there is a bearing and race the race is broke jus happened to my bravo one about a month ago about a three hour job .
La hustler is offline
