ac in a cig
Old 05-20-2005 | 01:16 AM
H20 Toie's Avatar
Default ac in a cig
So if i want ac in my cig how do i go about it, I assume that i will need a generator mounted in the engine compartment but does the ac unit go in there to or is it in the cabin?
Is there a factory setup for the generator?
Since i was use to having a bimini top on the old boat for shade and have not seen one for the cig i figured ac would would be the next best thing to get out of the heat while parked.
H20 Toie is offline
Old 05-20-2005 | 06:33 AM
AKA NoMoBoatin
Default Re: ac in a cig
Call Cig. and should have all the specs when they install a/c and gen set up from the factory.for shade buy a umbrella call sunshade.portable and easy set up.
docmanrich37 is offline
Old 05-20-2005 | 07:11 AM
vette131's Avatar
my ac is in the cabin but there are some ac units that mount in the engine compartment & the evap core & vent gets mounted in the cabin. it's alot easier to mount the all in one
type in a boat thats already completed.
vette131 is offline
Old 05-20-2005 | 07:14 AM
OldSchool's Avatar
Good luck on getting a return call!!
OldSchool is offline
Old 05-20-2005 | 10:11 AM
grimmy's Avatar
what he said
grimmy is offline
Old 05-20-2005 | 11:44 AM
Look at the unit they put into Concepts. No gen needed it runs off of cool water in a cooler. Saw one in Key west and it worked great.
wananewboat is offline
Old 05-20-2005 | 11:51 AM
I have friends that use the carry on portable units that sit on the deck when parked at the marina docks...they mount over the hatches....they seem to work well.....Fred
fred is offline
Old 05-20-2005 | 12:51 PM
Poorsche's Avatar
Check Mermaid Marine Air--they have excellent h/w and it has smallest footprint of any of them. The cpmay also has a cool product called Condensator--it uses the cooling water to pull the condensate overboard rahter than dumping it in the bilge.
They are in Ft Meyers
Poorsche is offline
Old 05-20-2005 | 01:20 PM
There is one of the carry-on type units I mentioned above for sale in the swap shop section for $300.00....check it out....Fred
fred is offline
K-WELLS
Classic Offshore
37
05-23-2008 08:09 PM
mikeb4
Cigarette
14
08-31-2007 09:04 AM
Air Dog
06-16-2006 08:50 PM
LEOPAJM
Cigarette
11
09-30-2002 12:14 PM
Crazyhorse
09-05-2002 08:46 AM
