hp 500 valve springs >
Old 05-24-2005 | 09:11 AM
Default hp 500 valve springs
need to change valve springs on my hp s they are all stock and orig 97 vintage i think springs were made by crane would prefer not to use crane again everones changing to comp cams anyone know the part#s or any other suggs thanks
smokin' gun is offline
Old 05-24-2005 | 12:01 PM
Perfectmix's Avatar
Default Re: hp 500 valve springs
This is what I have.
Valve Springs Comp 929-16
Retainers Comp 741-16
Keepers/Locks Comp 612-16
Seals Comp 505-16
Good Luck!
Perfectmix is offline
Old 05-24-2005 | 12:06 PM
did you use these part # to replace all your stock parts and are you still running the stock cam hyd roller
Old 05-24-2005 | 03:32 PM
Perfectmix's Avatar
Only replaced Valve springs, retainers,locks,seals, the cam is fine and so are the lifters. Matter of fact the springs were fine just didn't want to find out the hard way.
Old 05-24-2005 | 04:51 PM
Mudball's Avatar
I recently replaced mine too.
Went back with the Comp 929-16's, and new Crane retainers and keepers. It doesn't matter which retainers and keepers you use. They are the same dimensions...
My 1999 HP500 carb had 180 hours on it and had VERY weak springs all the way around. Two valves were spinning...
My cam and lifters were also perfect.
Kent
Mudball is offline
fastech69
1
09-26-2005 03:56 PM
dean brown
4
09-24-2005 12:55 AM
Summer Heat
2
02-21-2005 04:26 PM
rssteiny
1
10-16-2003 07:52 PM
gofastpilot
4
06-27-2002 01:25 PM
