Best $18.94 oil and filter change....
I was asked what is the best oil and filter that gives excellent protection at a good price. Well after a couple hours of research here it is you cheapskates (just kidding)
Either Castrol Synthetic Blend 20W-50
OR
Quaker State HP Synthetic Blend 20W-50
Both are equally good...both outperform the best 20W-50 conventional oils of any brand and both retail for $2.99/qt
$2.99/qt x 5 = $14.95 per engine
A/C makes the best pleated paper oil filter and costs $3.99;
for the "short version" part # A/C 454 or "tall version" part # A/C 1218.
Oil plus filter:
$14.95 + $3.99= $18.94 per engine
Twins = $18.94 x 2 = $37.88 (about 1/2 the price of using Mobil-1 oil and filters. Even I could take a second glance at this as not everybody truly needs synthetic oil.
Nothing but going up to the fully synthetics can beat these oils. You could use this oil with a Mobil-1 oil filter as well.
M1- 111 is the "short" and M-1 301 the tall. They go for
$ 10.99 ea.
So there you have it....these oils both out spec. Kendall; Castrol GTX 100% dino juice etc....for about 50 cents a quart more. You can use them all the way up to an 1100 HP engine if you wish. They outperform conventionals by about 20% due to the partial synthetic base mixture and a very good additive system in both.
If I used this combo I would see no problem going out to 50 hours on stock engines if the manufacturer offered that as an option.
OR
Oil plus filter:
$ 10.99 ea.
Originally Posted by mopower
How about 12 quarts..........each
Mine holds eight.
Which spec? What are you basing your facts on? Aren't most blends only 15-20% synthetic? How exactly do these oils "outperform" dino? On extended oil changes? What about 20 hour changes?
