Crane Rockers
Yes I am sure of the numbers, I couldn't find the 13767 number on the Crane site either.
Mystery solved, the part # has changed to 13763
The 13767's are a new version by crane. They are pre notched to clear the stock valve covers. No need to grind the corners off anymore. I just put a set on my 502MPI. They worked great.
Originally Posted by mobilecal
Nothing against you, but I never understood why people would grind on rockers and desturb the integrety of the rocker when a new valve cover for that depth is so cheap. High RPMs on the water , well can you say snap crackle pop...
Crazyhorse I agree. If you think of it there are that same many thousand rockers out there w/ an extra 500lbs. over the nose still running today.That radius ground on the rocker causing a problem is like the chance of getting hit w/ a dick in a rainstorm .
zimm17
5
05-25-2007 09:24 PM
