How to put a new impeller in Raw Water Pump?? >
Old 06-06-2005 | 07:29 AM
East Coast B's Avatar
Question How to put a new impeller in Raw Water Pump??
I have a 1994 454mag and would like to know how to replace the water impeller on the raw water pump? They are fine right now, I want to get a spare impeller or impeller kit to carry with me, therefore would like to know what I'd have to do in the case one of the impellers failed?
I see you can order just an impeller or an impeller w/kit. What would I need?
I see that there are two hoses that have to come. Now, does the entire housing have to come off or can you take off just the back housing where the two hoses connect and get the imnpeller in that way??
Thanks for your help!!!
East Coast B is offline
Old 06-06-2005 | 07:44 AM
Default Re: How to put a new impeller in Raw Water Pump??
eastcoast
take the pump off and get the whole kit it comes with gaskets and wear plates.make sure you use wd40 on the impellerits a lot easier to install.the job should take you about ten-fifteen mins after you remove the pump.dont over tighten the bolts.
sonic28 is offline
Old 06-06-2005 | 08:44 AM
dtsquest's Avatar
Like Sonic said, pulled the pump, much easier to remove the impeller. Buy the kit and lube it to install it. They're pretty easy to replace.
dtsquest is offline
Old 06-06-2005 | 09:14 AM
Looks like the kit has two metal plates and 3 gaskets along with impeller, is that the kit you guys are referring to??
Thanks for your help! Looks like the hard part is just the removal of the unit.... $40 bucks sound right for the kit?
Old 06-06-2005 | 09:20 AM
HiPerf2000's Avatar
Thought the kit was more like $75 or so ?
HiPerf2000 is offline
Old 06-06-2005 | 10:26 AM
Sydwayz's Avatar
Forum Regulator
Wrap a zip tie around the new impellor, and sinch it down to make all the impellor veins lean in the direction they need to go when in the housing. Get the impellor 2/3s of the way in by twisting with a little silicone spray or dish soap, then cut off the zip tie, and work it the rest of the way in. Works like a champ.
Sydwayz is offline
Old 06-06-2005 | 10:49 AM
On the link below, look at GLM12085, is this the kit??
http://ebasicpower.american-data.net...ory_Code=MER5J
Old 06-06-2005 | 11:58 AM
yup that's the one
good luck
sonic28 is offline
Old 06-06-2005 | 02:52 PM
HiPerf2000's Avatar
The one i am thinking of also comes with a new plastic housing.
Old 06-08-2005 | 10:19 AM
I just did this about three weeks ago. I would suggest a little dishsoap on the inside of the housing to get the impeller to go in smoother. The soap also helps to lubricate it before the water gets into the housing initially. Four bolts will go all the way through the mounting bracket. One of them will not. Be sure that the one bolt is not sticking out to far and hitting the mounting bracket. If it does and you crank the other four down the housing of the pump will crack around where that fifth bolt is. (If you can't tell I am speaking from experience) Good luck...fairly easy job other than the pump is on the bottom of the engine.
zog02 is offline
