Propeller for 280 >
Propeller for 280
Propeller for 280
Old 06-10-2005 | 03:14 PM
velocitypwrbtr's Avatar
Default Propeller for 280
What is the best prop for a 280 with a 540 600hp? What is everyone seeing for prop slipage?
velocitypwrbtr is offline
Old 06-10-2005 | 08:03 PM
Default Re: Propeller for 280
I would call Mike at Hall propeller. He is a genuis at working Velocity Props. I am running a labbed 26 Hydro but with a mostly stock 502 mag. what are you running now?
Padraig is offline
Old 06-10-2005 | 08:22 PM
28p Hydro @ 5400 rpm would like to try a bravo one 4-blade I have too much slippage and cavitation
Old 06-11-2005 | 06:15 AM
bglz42's Avatar
On my 26 Thoroughbred, I'm running a Halls labbed Bravo 30". My slip numbers are still a little high, but the midrange is better than my old Hydro. Also, I like the handling much better with the Bravo. I think I gave up a little speed, but it was worth it. I tried a new (unlabbed) 26" Hydromotve Q5X five-blade, (borrowed), and it was NICE! Picked up some serious mid (3500 rpms/50mph) and felt really good. That's my next prop for sure. Slip as down to around 10-12%, too.
Jim
bglz42 is offline
Old 06-27-2005 | 08:46 PM
FFO
bglz42 What H.P are you running . Also what top speed did you see with 5 blade .
FFO is offline
Old 07-08-2005 | 05:39 PM
velocity280's Avatar
I have a '96 280 with 540 and a little over 600 hp and run a labbed 30 bravo by Mike Hall. He says I really should use a 32, but don't have the extra money. I have turned the prop as high as 5600 rpm at about 83 on gps. Hit a little sand bar here at Havasu and took some of the edge off and down to around 5400. My mid range is awsome...I can accelerate as fast as a lot of blown boats.
velocity280 is offline
Old 08-31-2005 | 06:46 AM
offshorebankin's Avatar
30 lab all the way...
offshorebankin is offline
Old 12-22-2005 | 10:14 PM
I had a 280 with HP500 and B&M Blower approx 650Hp.
With 30P Bravo 1 rode too flat and 85 MPH
With 29 labbed hydro totally different attitude and 88 MPH.
I recommend the hydro labbed hands down. I did not like the Bravo at all!
docbones is offline
Old 12-24-2005 | 08:42 AM
mikes280's Avatar
i run a 32labbed bravo turn it right at 6000 but i thank it runs to flat may let mike do some work on it for next summer i also wont to try a 5 blade
mikes280 is offline
Old 01-02-2006 | 01:34 PM
what kind of speed should a 280 (1996) with a merc 500 carb see?
risky is offline
