Bent Blades? Home repair How to? >
Old 06-11-2005 | 02:11 AM
Dregsz's Avatar
Default Bent Blades? Home repair How to?
Directions please on how to remove and correctly pound out a bent blade on a SS prop?
mounted on a Yamaha OB
Evan
Dregsz is offline
Old 06-11-2005 | 04:00 AM
Default Re: Bent Blades? Home repair How to?
You can't do it "correctly" without the blocks for the prop.
Griff is offline
Old 06-11-2005 | 04:32 AM
Dregsz's Avatar
I'm going to do it anyway, so please help me out.
Dregsz is offline
Old 06-11-2005 | 06:51 AM
OldSchool's Avatar
Just get a 4x4 and a big azz hammer and pound that beeotch until it looks good!!!! It aint rocket science.
...the real trick is to buff it when you're done. That's what makes 'em look so good.
OldSchool is offline
Old 06-11-2005 | 07:46 AM
throttleup's Avatar
The most difficult part is mounting the prop so it can be worked. Typically if it's not worked on a block it is mounted to a very heavy steel table. After it's firmly mounted use a couple of hammers and start working the prop till it looks right. You can get pretty close just by eye balling it. Steel hammers will leave dings in stainless steel. Then start sanding it with progressivly finer sand paper, buff it up and you are good to go.
throttleup is offline
Old 06-11-2005 | 10:43 AM
Or send it to Julie @ Throttle -up, they did a prop for me last year and I gartuee it looks better than yours. :-)
J/K, I just wanted a chance to plug the good folks at Throttle up.
Mike
happy hours is offline
Old 06-11-2005 | 10:53 AM
The Menace's Avatar
Dings in props usually translate to bends in prop shafts that should most times are not visually detectable. You should have your lower unit checked out.
Begin by running a TIR (total indicator runout) on your propr shaft. If you do not know how to do one this would be a good time to learn. A TIRis real simple and can be performed right on the boat.
The Menace is offline
Old 06-11-2005 | 04:00 PM
robyw1's Avatar
Now that is determination!
Roby
robyw1 is offline
Old 06-11-2005 | 09:59 PM
mwdill's Avatar
Roby
i think we have all been there
mwdill is offline
Old 06-13-2005 | 12:05 AM
Dregsz's Avatar
Phone # for throttle up please?
Mike
Dregsz is offline
