Labbed prop poll:  what were your results ?? >
View Poll Results: top end results after having your prop labbed
rpms went up, no mph gain.
12
14.29%
gained 1mph
7
8.33%
gained 2mph
25
29.76%
gained 3mph or more
24
28.57%
don't waste your money, it ain't worth it..
16
19.05%
Voters: 84. You may not vote on this poll
Old 06-15-2005 | 09:40 AM
Chris288's Avatar
Default Labbed prop poll: what were your results ??
What were your top end results after having your prop labbed ??
Chris288 is offline
Old 06-15-2005 | 09:47 AM
BajaRunner's Avatar
Default Re: Labbed prop poll: what were your results ??
allan4 is a putz
BajaRunner is offline
Old 06-15-2005 | 09:50 AM
Milord's Avatar
I went up 3 mph, my mid range went up 5mph, better hole shot. It was Houston's Accelerator design change on Mirage +'s. Bow carried much better than before as well.
Milord is offline
Old 06-15-2005 | 09:55 AM
BajaRunner's Avatar
thats impressive.
Old 06-15-2005 | 10:11 AM
Indy's Avatar
Member #154
Compared to the experimentation, returned props, cupping changes, pitch modifications, and the small results, I'll never do it again. I might send them out to be balanced but 1-2 mph on the top end (where I spend little time) isn't worth it. My experience also showed a slight gain in top end, but I lost cruise which is where I spend much of my time. A couple of mph doesn't mean jack to me, if I want significantly bigger speed numbers, it's time to look at new power or a new boat.
This was also on a little 28' single engine boat that might not be the best platform for these types of changes.
Indy is offline
Old 06-15-2005 | 10:33 AM
BlownRat's Avatar
Had a pair of "box stock" 32P Bravo 1's labbed by Mercury...
Brought 'em down to 31P...
I saw a 200 increase in RPM and maybe 1 or 2 MPH on the top end. Didn't notice any change in holeshot or mid-range.
BlownRat is offline
Old 06-15-2005 | 02:15 PM
robyw1's Avatar
DITTO
I had the same results with the Accelerator on my 22' Scarab
Roby
robyw1 is offline
Old 06-15-2005 | 02:22 PM
Chris288's Avatar
a lot of mixed results,,, seems the 3 blades are doing pretty well after labbing..
Chris288 is offline
Old 06-15-2005 | 02:39 PM
Milord's Avatar
Just to clarify, I have twins and was not pulling enough rpm's with my props before they went to Houston.
Milord is offline
Old 06-15-2005 | 04:25 PM
VT32SSR's Avatar
I had labbed 30 Bravo1 on my Velocity 290.My prop now is a 27p5X.Speeds up to 4000 rpm were off by 5 to 8 mph off with the 30.Top end is at 82 with both at 5300 rpm.3500rpm was 48 with the Bravo1,and 55 with the Hydro27.The 5 blade is untouched.Chris I hoped to see you at the milk run.
VT32SSR is offline
