jet boat help >
jet boat help
jet boat help
Old 06-16-2005 | 06:30 PM
Default jet boat help
A EMPLOYEE OF MINE HAS A JET BOAT W/ WATER INJECTED HEADERS AND ONLY GETS WATER OUT OF ONE HEADER AND ALL THE LINES TO THE OTHER HEADER SEEM WIDE OPEN. ANY ADVICE.
OR ANY PLACES WE CAN CALL THAT ARE MOSTLY JET BOATS.
THANKS.
rssteiny is offline
Old 06-16-2005 | 07:31 PM
CPPerformance's Avatar
Default Re: jet boat help
Have him call us at 800-225-9871. We sell both Rewarder and Bassett water injected headers as well as Berkeley Jet Drives.
CPPerformance is offline
Old 06-16-2005 | 11:04 PM
Wobble's Avatar
SORE MEMBER
Probably needs to clean out orifice where water line connects to 4 header water injection lines. Real easy to get them stopped up.
This assumes correct plumbing and sufficient flow to headers. Normally most water exiting engine goes into tail end of exhaust or over the side. Water to header injection is controlled by a gate valve that can be pinched off or opened up to get more spray.
Generaly water comes from jet pump to "tee" to both water pump ports to engine. Then exits at t-stat area and splits 3 ways. 2 go to each exhaust tailpipe and third goes thru gate valve and on-off spring valve to "tee" that feeds header sprayers.
If u have a t-stat it gets way more tricky. But above is how most jets were done
Wobble is offline
Old 06-16-2005 | 11:29 PM
Wobble's Avatar
SORE MEMBER
Also there are 1/8" or so weep holes at the bottom of each header bend by sparkplug to allow excess water to drain from headers. Make sure these are open.
Wobble is offline
THEJOKER
03-28-2008 01:51 PM
JLAY
Donzi
5
01-26-2008 10:08 AM
J-Bonz
Apache
2
08-10-2007 04:23 PM
cig1988
6
08-01-2005 07:55 AM
boot
01-21-2002 08:19 AM
