Intercoolers for 1471 blower motors- Worth the money? >
Old 06-26-2005 | 06:27 PM
Default Intercoolers for 1471 blower motors- Worth the money?
wondering if installing intercoolers on a blower motor with increase life of motor, and does it increase hp and performance or just allow you to run more boost? thanks- who makes the best one for the Blower shop 1471?
Buddy OO is offline
Old 06-26-2005 | 07:10 PM
Default Re: Intercoolers for 1471 blower motors- Worth the money?
Yes they are a must..they cool the air after it is compressed.
Byrdman is offline
Old 06-26-2005 | 08:33 PM
Fred looking for 3 for my 50 nortech, whaat brand do you recommend, also do they come with the hoses and plumb kit,. thanks Jim midwest performance marine --loto
Buddy OO is offline
Old 06-26-2005 | 08:42 PM
JCPERF's Avatar
I think you have to run them anyway because the distributor wont clear the blower
JCPERF is offline
Old 06-26-2005 | 11:18 PM
Outdrive1's Avatar
Masher touches my
I'm no expert but I would say any blower motor should have an intercooler, not only is it cheap horsepower but cooling your intake charge helps with detonation among other things. Could anybody make an argument not to have an intercooler?
Outdrive1 is offline
Old 06-26-2005 | 11:55 PM
Papache's Avatar
Registered User
If you use psi blowers you don't need them
Papache is offline
Old 06-27-2005 | 12:22 AM
Coolerman's Avatar
PF Marine
Sterling, Paul Pfaff and several others use intercoolers when they build their PSI motors. PSI says you don't need them, which is true, but they sure help.
Coolerman is offline
Old 06-27-2005 | 07:56 AM
GLH's Avatar
GLH
I do not know about 1471's but I can tell you what happened when i added chillers on my B&M 420 Mega Blowers.
1. Fred sold them to me and his service was as good as his incapacity to get that Sutphen wet... in other words.... AWESOME SERVICE.
2. Originally I ran 6# of boost and the boat ran everyday 78.5mph with taps at 80.3 when only fumes left in the tank and two on board. All this on fresh water.
3. Added the chiller the boost is down to 4.8-5# due to the larger intake area but I see 80's consistently. I have not changed my props yet but will do so soon. I also am ordering pulleys to get the boost back up to 6#. I imagine it will give me 82's day in day out with light runs close to 84. Again all in fresh water.
4. I would be carefull of flushing those systems religously if you use them in salt water from related experience to me by multiple world champion of cores rotting out in salt water enviroment. For me it is a non issue.
5. I installed them myself without any hitched and I am an idiot so they are pretty easy to put on. You'll need belts 8" longer also. All I need now is get the bling bling hose fitting and right lenght braided lines but the setup is sound currently and the boat runs like a raped ape.
My evaluation is easily 40-50hp per mills in my application once the boost will be back to the original setting.
This crap is on a 2000 42 Cigarette Tiger with 509's CR 8.1.
Hope this helps.
Attached Thumbnails Intercoolers for 1471 blower motors- Worth the money?-img_0700-mr.jpg   Intercoolers for 1471 blower motors- Worth the money?-img_0686-mr-2.jpg   Intercoolers for 1471 blower motors- Worth the money?-fpc-run5.jpg
GLH is offline
Old 06-27-2005 | 08:11 AM
375stinger's Avatar
trick, do you sell weiand 256 supercharger kits? Im considering installing them on the cig this winter. could i keep a single holley dominator carb or would i need two carburetors?
375stinger is offline
Old 02-01-2009 | 10:58 AM
any time you compress air,you also heat it,even with a psi,the psi by design makes less heat,but still will benefit from cooling the air charge.
mike tkach is offline
