Ignition Problem 280ss >
Old 06-28-2005 | 08:27 PM
Default Ignition Problem 280ss
Stbd Engine, turn key nothing. Have 12V on Ignition until turn the key, then drops to 0v. If I run a 12V bypass to ignition switch all is well, but obvioisly cant keep it like this. Any help? Thanks..Phil
PJSALERNO is offline
Old 06-28-2005 | 10:10 PM
Default Re: Ignition Problem 280ss
I guess you are refering to an outboard. First place to look is the harness plug or loose conection on the starter solonoid. If you can switch the key switch harness from the other motor that will help isolate the problem. You will get a much better responce on the screamandfly board if that does not work
mmwalters is offline
Mike Paula
9
08-07-2006 08:08 PM
biginches
6
09-02-2005 02:45 PM
Ran-Dom 32
9
03-26-2003 02:27 PM
26sonic
09-23-2002 08:02 PM
jrocket
3
05-14-2002 08:28 AM
