drive oil leaking inside bilge??? >
Old 06-29-2005 | 06:19 PM
5PMSMWHR's Avatar
Default drive oil leaking inside bilge???
28 ft donzi twin 350 mags, bravo one drives, went out last week and greeted by beeping when I pulled back to dock. Marine guy said most likely impellers so replaced both. just got boat back and notice drive oil leaking down the back of the port drive inside the engine compartment. Thoughts as to what I'm looking at here? Thanks in advance,
5PMSMWHR is offline
Old 06-29-2005 | 07:03 PM
Default Re: drive oil leaking inside bilge???
Just Had The Same Problem Runnin In A Poker Run And Started Beaping Found The 1 Drive Bottle Was Empty Pulled It Off Found Back Of Bottle Wet From Cap Down, I Found That The Rubber Gasket In The Cap Was Missing When Running Hard It Builds Pressure In Bottle And Was Pushing Out The Cap Because The Seal Was Missing.
rssteiny is offline
Old 06-29-2005 | 08:28 PM
5PMSMWHR's Avatar
thanks for the response but I'm seeing the oil where the drive and engine connect on the inside of the engine compartment. ???????????????
5PMSMWHR is offline
Old 06-29-2005 | 08:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Check the hose connection at the transom plate. It's just a simple slip on with a push button lever to hold it on. They are somewhat loose when installed and rely on the o-ring to seal. Right under the water inlet hose, fairly easy to reach and diconnect.
US1 Fountain is offline
Old 06-29-2005 | 10:51 PM
tcelano's Avatar
If you are seeing oil draining out from the u-joint bellows, your drive's upper gearcase oil seal is shot. That's the most likely culprit if you are seeing oil as you describe. The beeping you heard was most likely the low drive oil warning. To fix it, the drive needs to come off, but that's pretty quick and easy, and you can have your motor alignment checked at the same time. If the drive has been run low on oil, you could have other issues in there, but hopefully this hasn't been going on for long enough to cause a major problem.
tcelano is offline
Old 06-30-2005 | 10:55 AM
mr_velocity's Avatar
Yup upper drive seal, probably need to replace the shaft was well.
mr_velocity is offline
Old 06-30-2005 | 11:07 AM
Wobble's Avatar
SORE MEMBER
Make sure you regrease the bearing. The drive oil could have flushed the grease out.
Wobble is offline
Old 07-14-2005 | 01:21 PM
5PMSMWHR's Avatar
And the winner is the upper gear case oil seal. Thanks for all the the help. Fixed in time for what should be an awesome weekend on Lake Ontario.
5PMSMWHR is offline
Old 07-14-2005 | 01:29 PM
Wobble's Avatar
SORE MEMBER
Thanks for the update.
Enjoy a safe boating weekend, I plan to.
Wobble is offline
Reckless32
0
07-05-2005 04:56 PM
BAJA WILL
3
07-21-2004 10:57 AM
Velocity Tom
07-16-2003 10:13 AM
GLH
11
04-28-2003 12:24 PM
Sydwayz
3
06-24-2002 08:23 AM
