Water leak Bravo 1 >
Water leak Bravo 1
Water leak Bravo 1
Old 07-01-2005 | 03:19 PM
Default Water leak Bravo 1
Over the winter I had to rebuild my engine the guy that installed it and he outdrive is gone and I have water slowly filling my bilge. Having never had this problem does anyone have a idea what the cause could be?
MetraMan is offline
Old 07-01-2005 | 03:36 PM
Smitty's Avatar
Default Re: Water leak Bravo 1
Unfortunately there are many places the water could be coming from since the motor and drive were removed. Best to take it to a Pro and have them correct the problem.
Smitty is offline
Old 07-01-2005 | 08:08 PM
Checked it twice couldn't beleive it was leaking, very slow but leaking. I hope it does not soak my hull.
MetraMan is offline
Old 07-01-2005 | 09:34 PM
hillbilly24's Avatar
Take it to the ramp, leave the back tie downs on and back it in until the transom plate is tottaly submerged. Use a flashlight and an inspection mirror and you will be eable to find it. It's better to do it durring the week cuase your'e gonna block the ramp for a while.
hillbilly24 is offline
Old 07-01-2005 | 09:40 PM
Outdrive1's Avatar
Masher touches my
Hillbilly has a good idea, you could also run it on the hose and see if you have a water leak in your cooling system. If you take it to the ramp though you can look for leaks running and not.
Outdrive1 is offline
Old 07-02-2005 | 12:42 PM
Found my leak it's below the drive shaft 2 allen bolts holding a plate with about 9/16 dia. hose passing thru out to the drive.I don't see a good explanation in my stern drive book.Any suggestions I assume the drives got to come off?
MetraMan is offline
Old 07-02-2005 | 01:29 PM
Wobble's Avatar
SORE MEMBER
the 9/16 tube, does it go to the reservoir bottle or is it the speedo tube?
Wobble is offline
runnin gun
Sonic
14
09-25-2006 10:15 PM
xhere
8
01-29-2006 10:23 PM
waterbum
0
08-15-2005 10:36 AM
LLcoolBaja
23
06-01-2004 01:13 AM
stevel
7
05-31-2002 01:45 AM
