CMI Header/Tailpipe Confusion
I purchased a CMI Header from a performance dealership that went out of business. It was off of a Merc 500 EFI. They also threw in brand new tailpipes and clamps and I need to know if they are compatible. If so, what clamp and gasket do I need? Rope style? Flat gasket? I've heard so many conflicting stories (bench mechanics) that I don't know what I need. I've included pictures of header, tailpipe, and clamp. If these are not compatible, what parts do I need?
You will need the flat gasket. I use 2 per side. If you buy them direct from CMI they want way too much money for them. You will also need the molded U hose that connects the header to the tail pipe. The pictures do not show the bolt & nut that go with the clamp. You will need that also.
